[GRASS-dev] -s flag in temporal modules
Anna Petrášová
kratochanna at gmail.com
Tue Feb 23 06:52:32 PST 2016
On Tue, Feb 23, 2016 at 9:02 AM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> On 19 February 2016 at 14:31, Luca Delucchi <lucadeluge at gmail.com> wrote:
> > Hi devs,
> Hi again,
> > according to this ticket [0] Soeren added the -s flag to
> > t.rast.aggregate and t.rast.aggregate.ds, I would like to extend (I
> > already started) this flag to all the temporal modules using basename
> > option. I discovered that -s flag is used in other modules for other
> > meanings.
> > In grass70 the only modules with basename and -s are t.rast*.mapcalc
> > (-s is used also by t.sample). In grass71 several other modules are
> > using -s.
> > I would like to standardize the -s for the "start time" and also the
> > other flags in the temporal modules.
> > I would like to modify trunk and release the new flags only in the
> > next major release, what do you think?
> > [0] https://trac.osgeo.org/grass/ticket/2294
> nobody has to suggest a way to follow?
> without any comment against tomorrow I'll start to commit changes in trunk
Are we releasing 7.1 from current trunk? Any way we can make the changes in
7.1 in a compatible way? If not (in case of t.sample) we might say the
interface is a bug and fix it, I would like to avoid waiting for the
changes till GRASS 8.
Thanks,
Anna
> ciao
> Luca
> www.lucadelu.org
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160223/c4f75a57/attachment.html>
