[GRASS-dev] Fwd: Re: [OSGeo-Discuss] OSGeo4W maintenance activities
Radim Blazek
radim.blazek at gmail.com
Wed Feb 24 00:50:09 PST 2016
On Sun, Feb 21, 2016 at 4:19 PM, Markus Neteler <neteler at osgeo.org> wrote:
> FYI
> (ongoing discussion in the other list)
> ---------- Forwarded message ----------
> From: "Jürgen E." <jef at norbit.de>
> Date: Feb 21, 2016 4:14 PM
> Subject: Re: [OSGeo-Discuss] OSGeo4W maintenance activities
> To: <discuss at lists.osgeo.org>
> Cc:
> Hi Markus,
> On Sun, 21. Feb 2016 at 15:47:00 +0100, Markus Neteler wrote:
>> since I'm not familiar with compilation on Windows, could you briefly
>> indicate what's needed / which efforts to compile GRASS GIS with MSVC
>> rather
>> than mingw given the recent efforts on the 64bit packaging? Just to
>> better
>> understand...
> Not sure. I'd probably start with moving the build system to CMake. Like I
> already did for just the GRASS libraries at some point in the past (some
> code
> changes I submitted to make the libraries build with MSVC were also accepted
> back then).
> But moving all the modules there is probably a much bigger task and I'm also
> not sure about the acceptance of this. ;)
> It might also be possible to integrate msvc into configure/make (at least I
> think I've seen configures with MSVC stuff in them). Although you'd still
> need
> a unix like shell, make and other tools from mingw/cygwin. But I never
> explored that option (mainly just because the CMake approach went much
> better
> with what I needed for QGIS).
> But again GRASS works fine in OSGeo4W AFAICT (and as you know and that's
> still
> not much ;)) and hence I don't see the big problem of mixing MinGW and MSVC
> DLLs.
For the GRASS provider/plugin in QGIS (and any application using GRASS
libs) it is really painful. Each has different size of off_t and
various hacks must be used to get it working, for example:
https://github.com/qgis/QGIS/blob/884c3ba8d/src/providers/grass/qgsgrassprovider.cpp#L101
Also, it is not possible to debug GRASS lib built with MinGW in an
application built with MSVC.
Radim
> It doesn't add much to the mess of having different MSVC compilers
> and
> runtimes around. IMHO that part of Rashad's issue is just a CMake bug and
> not
> a fundamental flaw in OSGeo4W.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on FreeNode
> Discuss mailing list
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
