[GRASS-dev] [GRASS GIS] #2761: v.net.path manual error
trac at osgeo.org
Wed Feb 24 06:22:30 PST 2016
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.4
Component: Vector | Version: 7.0.1
Resolution: invalid | Keywords: v.net.path, network
CPU: All | Platform: All
Changes (by mmetz):
* status: new => closed
* resolution: => invalid
Comment:
Replying to [comment:3 martinl]:
> OK, now I understand better your ticket. The 'id' is stored in created
attribute table, source:grass/trunk/vector/v.net.path/path.c#L100. Why do
you think that it should be a layer?
ID is correct, it is the ID of the path to be created. Layers are defined
with the arc_layer, node_layer, turn_layer, and turn_cat_layer options.
Several paths can be created at once, e.g. with
1 1 2
2 2 3
3 3 4
using the syntax "id start_point_category end_point_category". The output
will contain three different paths. You can then display a single path
with d.vect where="id = 1" etc. Closing as invalid.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2761#comment:8>
