[GRASS-dev] -s flag in temporal modules
Sören Gebbert
soerengebbert at googlemail.com
Wed Feb 24 06:44:13 PST 2016
Am 24.02.2016 15:35 schrieb "Luca Delucchi" <lucadeluge at gmail.com>:
> On 24 February 2016 at 13:36, Sören Gebbert
> <soerengebbert at googlemail.com> wrote:
> > Hi Luca,
> Hi Soeren,
> > I think your suggestion of using 2001-01-01T00.00.00 is a good solution.
> it seems no :-( for vector '.' is not SQL compliant
> I would like to use '_' instead '.', but I don't know if it is better
> to use it only for vector or also for raster, suggestion?
Lets use only underscores. They are used for the granularity suffix anyway.
Best
Sören
> > Best regards
> > Soeren
> ciao
> Luca
> www.lucadelu.org
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160224/7630153f/attachment.html>
