[GRASS-dev] [GRASS GIS] #2917: r.mapcalc neighbour modifier uses wrong row
trac at osgeo.org
Sat Feb 27 02:23:08 PST 2016
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.4
Component: Raster | Version: svn-releasebranch70
Resolution: | Keywords: r.mapcalc
CPU: Unspecified | Platform: Unspecified
Comment (by marisn):
Replying to [comment:4 glynn]:
> In the first case, a single command uses two distinct row offsets, which
causes the row cache to be used. In the second case, each command only
uses a single row offset, so the row cache isn't used.
> The precise test for whether the row cache is used is whether the number
of cached rows is greater than one and less than or equal to 8. The number
of cached rows is the maximum offset minus the minimum offset plus one.
See setup_map() in raster/r.mapcalc/map.c.
If I understood correctly, the issue was triggered by any mapcalc
expression containing two to eight references to same map (MAP[n,x] and
MAP[m,x], ...) where n!=m.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2917#comment:6>
