[GRASS-dev] installing wx.metadata fails
Paulo van Breugel
p.vanbreugel at gmail.com
Mon Feb 29 07:35:50 PST 2016
OK, thanks I'll give it another try. The installation of this addon in
particular remains a bit problematic, with every so many times a
failure. Anyway, happy it seems to install again.
Paulo
On 29-02-16 13:14, Blumentrath, Stefan wrote:
> Hei,
> I had similar issues recently.
> Just now I tested again (fresh code for both GRASS 71 and AddOns) and
> the metadata tools seem to work.
> However, I get still get an error message on compile:
> GISRC=/usr/local/grass-7.1.svn/demolocation/.grassrc71
> GISBASE=/usr/local/grass-7.1.svn
> PATH="/usr/local/grass-7.1.svn/bin:/usr/local/grass-7.1.svn/bin:/usr/local/grass-7.1.svn/scripts:$PATH"
> PYTHONPATH="/usr/local/grass-7.1.svn/etc/python:/usr/local/grass-7.1.svn/gui/wxpython:$PYTHONPATH"
> LD_LIBRARY_PATH="/usr/local/grass-7.1.svn/bin:/usr/local/grass-7.1.svn/bin:/usr/local/grass-7.1.svn/scripts:/usr/local/grass-7.1.svn/lib:/usr/local/grass-7.1.svn/lib:"
> LC_ALL=C g.parser -t g.gui.metadata.py | sed s/\"/\\\\\"/g | sed
> 's/.*/_("&")/' >
> /usr/local/grass-7.1.svn/locale/scriptstrings/g.gui.metadata_to_translate.c
> /bin/sh: 1: cannot create
> /usr/local/grass-7.1.svn/locale/scriptstrings/g.gui.metadata_to_translate.c:
> Directory nonexistent
> make[1]:
> [/usr/local/grass-7.1.svn/locale/scriptstrings/g.gui.metadata_to_translate.c]
> Error 2 (ignored)
> make[1]: Leaving directory
> `/data/src/grass71-addons/gui/wxpython/wx.metadata/g.gui.metadata'
> Kind regards,
> Stefan
> *From:*grass-dev [mailto:grass-dev-bounces at lists.osgeo.org] *On Behalf
> Of *Paulo van Breugel
> *Sent:* 23. februar 2016 09:58
> *To:* GRASS developers email list <grass-dev at lists.osgeo.org>
> *Subject:* [GRASS-dev] installing wx.metadata fails
> I just tried to update the wx.metadata addon using g.extension (on
> grass 7 master), resulting in the error below:
> (Tue Feb 23 09:55:19 2016)
> g.extension extension=wx.metadata url=
> WARNING: Extension <wx.metadata> already installed. Re-installing...
> Fetching <wx.metadata> from GRASS GIS Addons repository (be patient)...
> Compiling...
> Traceback (most recent call last):
> File "/tmp/grass7-paulo-8596/tmpWf3irR/wx.metadata/scripts
> /db.csw.admin", line 127, in <module>
> from mdlib.cswutil import *
> ImportError: No module named mdlib.cswutil
> make[1]: *** [db.csw.admin.tmp.html] Error 1
> /g.gui.cswbrowser", line 22, in <module>
> from mdlib.cswlib import CSWBrowserPanel,
> CSWConnectionPanel
> ImportError: No module named mdlib.cswlib
> make[1]: *** [g.gui.cswbrowser.tmp.html] Error 1
> /g.gui.metadata", line 43, in <module>
> from mdlib import mdgrass
> make[1]: *** [g.gui.metadata.tmp.html] Error 1
> Installing...
> /usr/bin/install: cannot stat ‘/tmp/grass7-paulo-8596/tmpW
> f3irR/wx.metadata/docs/html/db.csw.admin.html’: No such
> file or directory
> make[1]: *** [install] Error 1
> f3irR/wx.metadata/docs/html/g.gui.cswbrowser.html’: No
> such file or directory
> f3irR/wx.metadata/docs/html/g.gui.metadata.html’: No such
> file or directory
> make: *** [installsubdirs] Error 2
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160229/ce6efb10/attachment.html>
