[GRASS-dev] [GRASS GIS] #2845: Build failure with 7.0.3RC1 on Linux
trac at osgeo.org
Sat Jan 2 18:46:00 PST 2016
Reporter: scimmia | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.3
Component: Compiling | Version: unspecified
Resolution: | Keywords:
CPU: x86-64 | Platform: Linux
Comment (by scimmia):
The patch helps significantly. I can now build successfully as long as I
use make -j1. When I use -j5 as I normally do, I still get an error, but
it's harder to track.
Makefile:53: recipe for target
'/home/dnewgard/PKGBUILDs/grass/src/grass-7.0.3RC1/dist.x86_64-pc-linux-
gnu/gui/wxpython/xml/module_items.xml' failed
Ticket URL: <https://trac.osgeo.org/grass/ticket/2845#comment:3>
