[GRASS-dev] [GRASS GIS] #2845: Build failure with 7.0.3RC1 on Linux
trac at osgeo.org
Sat Jan 2 18:57:31 PST 2016
Reporter: scimmia | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.3
Component: Compiling | Version: unspecified
Resolution: | Keywords:
CPU: x86-64 | Platform: Linux
Comment (by wenzeslaus):
Replying to [comment:3 scimmia]:
> When I use -j5 as I normally do, I still get an error, but it's harder
to track.
> Makefile:53: recipe for target
'/home/dnewgard/PKGBUILDs/grass/src/grass-7.0.3RC1/dist.x86_64-pc-linux-
gnu/gui/wxpython/xml/module_items.xml' failed
Replying to [comment:4 scimmia]:
> Shoot, pasted wrong line
> /bin/sh: /home/dnewgard/PKGBUILDs/grass/src/grass-7.0.3RC1/dist.x86_64
-pc-linux-gnu/gui/wxpython/xml/module_items.xml: No such file or directory
Are both there or just one? `module_items.xml` should be created as first
item in the `default` target and then it is required by following items
inside recipe for the `default` target (implicitly, all things inside one
target should always go in sequence AFAIK). These are the lines:
default: $(DSTFILES)
-$(MAKE) $(DSTDIR)/xml/module_items.xml
-$(MAKE) xml/menudata.xml
-$(MAKE) xml/module_tree_menudata.xml
Ticket URL: <https://trac.osgeo.org/grass/ticket/2845#comment:5>
