[GRASS-dev] [GRASS GIS] #1101: WinGrass7 + scripts are not found in the command line
trac at osgeo.org
Sun Jan 3 12:03:17 PST 2016
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.0
Component: Packaging | Version: svn-trunk
Resolution: fixed | Keywords: wingrass, scripts
CPU: Unspecified | Platform: MSWindows Vista
Changes (by hellik):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:15 wenzeslaus]:
> See also:
> * #580 WinGRASS: $GISBASE/etc/gui/scripts/ require something like
$(EXE) to run
> * #1871 winGRASS 7: solve python distribution
> * #2138 winGRASS6.4.svn - addon python script status?
> * #2150 Cannot call Python scripts from Python on MS Windows
> * [http://lists.osgeo.org/pipermail/grass-dev/2013-October/065896.html
Handling of Python scripts on MS Windows]
> * [http://lists.osgeo.org/pipermail/grass-dev/2014-February/067373.html
Handling of Python scripts on MS Windows] (question how QGIS and OSGeo4W
works)
> * r54612 - source:grass/trunk/mswindows -
[http://lists.osgeo.org/pipermail//grass-dev/2013-January/061451.html
wingrass: attempt to define python file association]
tested with
System Info
GRASS version: 7.0.3RC1
GRASS SVN Revision: 67443
Build Date: 2015-12-31
Build Platform: i386-w64-mingw32
GDAL/OGR: 1.11.3
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
it works; closing ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1101#comment:16>
