[GRASS-dev] [GRASS GIS] #1290: WinGrass: v.krige not working due to missing rpy2 pkg for MS Windows
trac at osgeo.org
Sun Jan 3 12:14:57 PST 2016
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: closed
Priority: major | Milestone: 6.5.0
Component: Vector | Version: svn-develbranch6
Resolution: wontfix | Keywords: wingrass, v.krige
CPU: x86-32 | Platform: MSWindows Vista
Changes (by hellik):
* status: new => closed
* resolution: => wontfix
Comment:
Replying to [comment:6 aghisla]:
> MarkusN suggested me to put a condition in the Makefile, like i.fft
module does, and skip v.krige compilation if dependencies are missing.
> Actually the only dependency visible at compile time is python-rpy2,
that I plan to remove. In order to fix the compilation error with present
codebase, I'd appreciate suggestions on how to check this Python
dependency in the Makefile.
> Would it make sense to make a new configuration parameter, like --with-R
> Ideas welcome!
> Many thanks,
> Anne
tested with
System Info
GRASS version: 7.0.3RC1
GRASS SVN Revision: 67443
Build Date: 2015-12-31
Build Platform: i386-w64-mingw32
GDAL/OGR: 1.11.3
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
v.krige
Loading dependencies, please wait...
ERROR: Python module 'Rpy2' not found. Please install it and re-run
v.krige.
from
http://rpy.sourceforge.net/rpy2/doc-2.1/html/overview.html#installation
Microsoft’s Windows precompiled binaries
If available, the executable can be run; this will install the package in
the default Python installation.
For few releases in the 2.0.x series, Microsoft Windows binaries were
contributed by Laurent Oget from Predictix.
There is currently no binaries or support for Microsoft Windows (more for
lack of ressources than anything else).
changing ticket to wontfix as rpy2's windows binaries are no longer
available.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1290#comment:7>
