[GRASS-dev] [GRASS GIS] #2814: digitizer crashes, leaves vector broken
trac at osgeo.org
Mon Jan 4 06:06:32 PST 2016
Reporter: harrikoo | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.3
Component: wxGUI | Version: 7.0.2
Resolution: | Keywords: digitizer, vector
CPU: Unspecified | Platform: Unspecified
Changes (by mlennert):
* priority: normal => blocker
Comment:
This seems to be a rebirth of #2439 and #2476.
I've just tested on trunk and on 7.0.3RC1 and I can confirm the following
behaviours of g.gui.vdigit:
1.
* Digitize one straight line.
* Digitize a second straight line that crosses the first
* Hit undo
=> Segmentation fault
2.
* Digitize an area with the last line crossing the first
* Undo
3.
* Undo
* Redo
I also again can see the same issue discussed in #2439 concerning the
dotted guiding line for digitization disappearing.
I don't know when this all reappeared, but at the time I'd done some
extensive testing and MarkusM's fixes worked for me. No idea why the issue
is back.
Declaring this as a blocker for 7.0.3 as this should just work, but could
others test and confirm ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2814#comment:1>
