[GRASS-dev] [GRASS GIS] #2848: g.gui.vdigit: snapping distance seems to only be defined in map units, not screen pixels
trac at osgeo.org
Mon Jan 4 06:23:36 PST 2016
screen pixels
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.3
Component: wxGUI | Version: svn-releasebranch70
Keywords: vector, digitize | CPU: Unspecified
Platform: Unspecified |
Using g.gui.vdigit in trunk and in 7.0.3rc1, I only seem to be able to
define snapping distance in map units, not in screen pixels:
* Go to the digitizing parameters, 'General' tab
* Change snapping threshold to any value, choosing screen pixels as unit
=> The translation to meters below always corresponds to the exact same
number you set as threshold in screen pixels. And testing through actual
digitization shows that the snapping threshold is in map units, whichever
unit you chose in the parameters.
Setting priority to major as snapping is an important tool in topological
vector editing, but the tool remains usable.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2848>
