[GRASS-dev] [GRASS GIS] #2846: g.gui.rlisetup: show where new config file is created
GRASS GIS trac at osgeo.org
Mon Jan 4 06:24:24 PST 2016
  Reporter:  hellik       |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.0.4
 Component:  Raster       |    Version:  svn-releasebranch70
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by hellik):
 Replying to [comment:3 lucadelu]:
 > Replying to [comment:2 mlennert]:
 > > Replying to [ticket:2846 hellik]:
 > > > it would be nice if there would be an information of the whole path
 to the file which could be copy/paste as input to the r.li.*-modules.
 > > You should not use the absolute path in the r.li.* modules. Just the
 file name. You can list existing files with g.gui.rlisetup. So, normally,
 no need to see the absolute path.
 > I confirm this
 > > However, ascii output files are also stored in the same path, and this
 is a bit more of a nuisance as you then have to navigate there to find the
 file. I imagine (but haven't checked) that this was done to ensure that
 any other r.li.* module can potentially, easily find the ascii output of
 another, but are there many modules that read this kind of output ?
 > Maybe you can open an enhancement ticket for this?
 > Can I suggest to close this ticket as invalid? I think it is better to
 use g.gui.rlisetup to create or modify the r.li configuration files.
 What kind of invalid is to show the path to config (and maybe the output)
 files?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2846#comment:4>
