[GRASS-dev] [GRASS GIS] #2834: v.db.select comand works, sqlite, attribute table does not open
trac at osgeo.org
Mon Jan 4 11:49:31 PST 2016
Reporter: khe | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: Database | Version: 7.0.2
Resolution: | Keywords: v.in.ogr
CPU: Unspecified | Platform: Linux
Comment (by hellik):
Replying to [comment:4 khe]:
> Hey Martin, thanks for your answer.
> <btw, why do you use o flag?
> I used the "o"-flag in order to override dataset projection (use
location's projection).
> The command itself ("v.in.ogr") is working. I can open the vector-data
of the the streams, roads...
> BUT I cannot open the attribute table by using the sqlite-database. I
connected the sqlite-database, the command "v.db.select" is working.
> When I want to open the attribute table a window opens saying "DMBI-
SQLite driver error: Unable to scan data...".
Anhang Schoenbuch_weg.shp hinzugefügt
shp-file
according to https://en.wikipedia.org/wiki/Shapefile#Overview for a
working ''shapefile'' following files are needed at least:
.shp — shape format; the feature geometry itself
.shx — shape index format; a positional index of the feature geometry
to allow seeking forwards and backwards quickly
.dbf — attribute format; columnar attributes for each shape, in dBase
IV format
could you post all 3 files (zipped) to test?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2834#comment:6>
