[GRASS-dev] [GRASS GIS] #2834: v.db.select comand works, sqlite, attribute table does not open
trac at osgeo.org
Tue Jan 5 02:07:28 PST 2016
Reporter: khe | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: Database | Version: 7.0.2
Resolution: | Keywords: v.in.ogr
CPU: Unspecified | Platform: Linux
Comment (by pvanbosgeo):
I cannot open the shapefile (the three files) you send in QGIS or GRASS.
Probably because the *.shx file is missing. But also note that the three
files (.shp, .shx, .dbf) should have the same name. The .shp file you
shared has another name than the .dbf and .sbx files.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2834#comment:8>
