[GRASS-dev] [GRASS GIS] #2850: v.db.update: value=NULL treated as text with NULL put between quotes
    trac at osgeo.org
    Tue Jan  5 05:07:33 PST 2016
 Reporter:  mlennert          |      Owner:  grass-dev@…
     Type:  defect            |     Status:  new
 Priority:  normal            |  Milestone:  7.0.3
Component:  Vector            |    Version:  svn-releasebranch70
 Keywords:  v.db.update NULL  |        CPU:  Unspecified
 Platform:  Unspecified       |
 v.db.update checks the type of the column to be updated and if it is not
 integer or double precision the content of the value parameter is
 automatically enclosed in single quotes.
 This causes a problem with the NULL value as the column is set to contain
 the string 'NULL' and not the NULL value.
 Currently the check is done as such:
 if coltype.upper() not in ["INTEGER", "DOUBLE PRECISION"]:
     value = "'%s'" % value
 We could just do this:
 if coltype.upper() not in ["INTEGER", "DOUBLE PRECISION"] and
 value.upper() != 'NULL':
 but this would mean that one could not put the string 'NULL' (or 'null')
 into a column.
 So, we can either decide that one should not use the string 'NULL', or we
 have to find a different way to handle the specific value NULL.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2850>
