[GRASS-dev] [GRASS GIS] #2814: digitizer crashes, leaves vector broken
trac at osgeo.org
Tue Jan 5 08:36:54 PST 2016
Reporter: harrikoo | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.3
Component: wxGUI | Version: 7.0.2
Resolution: | Keywords: digitizer, vector
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:2 annakrat]:
> You could try to isolate the issue by updating svn tree to some previous
versions. However, segmentation faults don't have to occur every time
which makes it difficult to find.
In my case the segfaults are systematic, so it's not that difficult.
I've been able to narrow down the range to somewhere between r64187 and
r64221, but have to stop now. MarkusM has done quite some work on the
vector libs during the time. Probably something in that is the culprit.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2814#comment:3>
