[GRASS-dev] [GRASS GIS] #2598: g.extension compilation fails
trac at osgeo.org
Tue Jan 5 17:54:06 PST 2016
Reporter: ewcgrass | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.3
Component: Default | Version: svn-releasebranch70
Resolution: fixed | Keywords:
CPU: x86-64 | Platform: Linux
Comment (by wenzeslaus):
Replying to [comment:14 rdzur]:
> r.damflood does not compile...
> main.c:223:9: error: expected ')'
> /usr/include/secure/_string.h:125:38: note: expanded from
> macro 'strcat'
> __builtin___strcat_chk (dest, src, __darwin_obsz (dest))
There was some unused code which caused the issue (seems like `strcat` is
a macro on Mac which caused a cryptic message, all fine with gcc 5.2.1 and
clang 3.6.2 on Ubuntu 15.10). Code removed in r67491.
In general, r.damflood would use some clean up (a lot of unused variables,
abs/fabs etc.).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2598#comment:15>
