[GRASS-dev] [GRASS GIS] #2852: ps.map fit frame to match region doesn't work
GRASS GIS trac at osgeo.org
Wed Jan 6 04:48:07 PST 2016
 Reporter:  pvanbosgeo  |      Owner:  grass-dev@…
     Type:  defect      |     Status:  new
 Priority:  normal      |  Milestone:  7.0.3
Component:  Ps.map      |    Version:  unspecified
 Keywords:              |        CPU:  Unspecified
 Platform:  Linux       |
 In ps.map fitting the frame to match the current region (or saved region)
 doesn't work. It generates the error code below. It looks like it has
 something to do with the code getting the degrees in DMS format instead of
 the D format when presumably setting the bounds.
   File "/usr/local/grass7/grass-7.1.svn/gui/wxpython/psmap/d
 ialogs.py", line 578, in OnApply
 ok = self.mPanel.update()
 ialogs.py", line 1065, in update
 self.scale[2], self.center[2], self.rectAdjusted =
 AutoAdjust(self, scaleType = 2, rect =
 self.mapFrameDict['rect'])
   File "/usr/local/grass7/grass-7.1.svn/gui/wxpython/psmap/u
 tils.py", line 222, in AutoAdjust
 regionDict = grass.parse_key_val(windFile, sep = ':',
 val_type = float)
   File "/usr/local/grass7/grass-7.1.svn/etc/python/grass/scr
 ipt/utils.py", line 224, in parse_key_val
 result[k] = val_type(v)
 ValueError
 invalid literal for float(): 15:06N
Ticket URL: <https://trac.osgeo.org/grass/ticket/2852>
