[GRASS-dev] results in winGRASS7 32bit vs 64bit: should they be identical?
Helmut Kudrnovsky
hellik at web.de
Thu Jan 7 02:53:32 PST 2016
Markus Neteler wrote
> On Wed, Dec 30, 2015 at 12:17 PM, Helmut Kudrnovsky <
> hellik@
> > wrote:
>>>Like this you check if the difference is very small and below the
>>>acceptable threshold.
>>>In C, we use GRASS_EPSILON for these comparisons.
>> now done with GRASS_EPSILON 1.0e-15
>> r.mapcalc expression=difftestepsilon = if( abs( accum32bit at accumtest -
>> accum64bit at accumtest) <= 1.0e-15, 1 , 100 )
>> attached a screenshot of this map
>> <http://osgeo-org.1560.x6.nabble.com/file/n5243286/accum_diff_wingrass32bitvs64bit.png>
> Mhh..
> Can you open a ticket with all relevant bits + the difference
> screenshot along with a legend and "r.univar -e" output?
done by https://trac.osgeo.org/grass/ticket/2854
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/results-in-winGRASS7-32bit-vs-64bit-should-they-be-identical-tp5243280p5244081.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
