[GRASS-dev] [GRASS GIS] #2854: results in winGRASS7 32bit vs 64bit: should they be identical?
trac at osgeo.org
Thu Jan 7 04:58:35 PST 2016
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: Raster | Version: svn-releasebranch70
Resolution: | Keywords:
CPU: x86-64 | Platform: MSWindows 7
Comment (by hellik):
Replying to [comment:2 hellik]:
> r.mapcalc expression=difftestepsilon_values = if(abs(
accum_wg32bit at watershedtest - accum_wg64bit at watershedtest ) <= 1.0e-15, 1
, accum_wg32bit at watershedtest - accum_wg64bit at watershedtest )
r.mapcalc expression=difftestepsilon_values2 = if(abs(
null() , accum_wg32bit at watershedtest - accum_wg64bit at watershedtest )
r.univar -e
map=difftestepsilon_values at watershedtest,difftestepsilon_values2 at watershedtest
total null and non-null cells: 4050000
total null cells: 1380680
Of the non-null cells:
n: 2669320
minimum: -8.14907e-010
maximum: 1
range: 1
mean: 0.51724
mean of absolute values: 0.51724
standard deviation: 0.499703
variance: 0.249703
variation coefficient: 96.6094 %
sum: 1380679.99999868
1st quartile: -1.77636e-015
median (even number of cells): 1
3rd quartile: 1
90th percentile: 1
Ticket URL: <https://trac.osgeo.org/grass/ticket/2854#comment:3>
