[GRASS-dev] [GRASS GIS] #2814: digitizer crashes, leaves vector broken
trac at osgeo.org
Thu Jan 7 05:59:57 PST 2016
Reporter: harrikoo | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.3
Component: wxGUI | Version: 7.0.2
Resolution: | Keywords: digitizer, vector
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:11 annakrat]:
> Replying to [comment:8 mlennert]:
> > Could others help testing if they can find any bad side effects of
this change ?
> The test cases work now for me as well.
Thanks for testing (and thanks for the tips on QtCreator).
AFAICS, the functions that were changed are only used in the wx digitizer,
so I don't have the feeling that there is much to be expected in terms of
unwanted side effects. I, therefore, think that we can backport.
Martin, will you do that, or should I (I don't know how much the code of
the digitizer has changed between trunk and release70) ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2814#comment:12>
