[GRASS-dev] [GRASS GIS] #2660: r.external / r.external.out: support paths relative to the mapset, and variables
trac at osgeo.org
Thu Jan 7 10:06:28 PST 2016
variables
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Raster | Version: svn-releasebranch70
Resolution: | Keywords: r.external.out
CPU: Unspecified | Platform: Unspecified
Comment (by glynn):
Replying to [comment:7 sbl]:
> Let`s say my GRASS DB is /grassdata/LOCATION/MAPSET and my external data
is on /raw_data/...
> The Windows equivalent is R:\grassdata\LOCATION\MAPSET and
R:\raw_data\... (let`s assume storage areas are mounted equally on Windows
and Linux (meaning in particular Windows`s drive letters do not change).
The specific case where both the database and GDAL files are on the same
filesystem probably isn't all that common. It's more likely that the two
will move relative to each other. E.g the database in a fixed location on
an internal disk or network share, the GDAL files on an external drive or
a different network share.
IMHO, any fix needs to be more general.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2660#comment:9>
