[GRASS-dev] Using GRASS addons in R on Windows
Paulo van Breugel
p.vanbreugel at gmail.com
Fri Jan 8 02:12:59 PST 2016
On Fri, Jan 8, 2016 at 10:39 AM, Helmut Kudrnovsky <hellik at web.de> wrote:
> pvanbosgeo wrote
> > In Windows running R from within GRASS (latter installed via OSGeo4W)
> > works fine, except that it can't seem to find the GRASS addons I
> > installed (with g.extension), not using rgrass7 nor directly using
> > system(). On Linux this is no problem, I can run any installed addon.
> > Any ideas how to solve this?
> what does echo %PATH% in the osgeo4w shell within the winGRASS session
> print?
> is the e.g. C:\Users\xy\AppData\Roaming\GRASS7\addons\bin included?
The following is included in the PATH:
C:\OSGeo4W\apps\grass\grass-7.0.2\lib
C:\OSGeo4W\apps\grass\grass-7.0.2\bin
C:\Users\Jeannette\AppData\Roaming\GRASS7\addons\bin
C:\OSGeo4W\apps\msys\bin
C:\OSGeo4W\bin;
C:\WINDOWS\system32
C:\WINDOWS
C:\WINDOWS\WBem
C:\OSGeo4W\apps\Python27\Scripts;
C:\Program Files\RStudio\bin
> best regards
> Helmut
> http://osgeo-org.1560.x6.nabble.com/Using-GRASS-addons-in-R-on-Windows-tp5244240p5244241.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160108/772b5f05/attachment.html>
