[GRASS-dev] [GRASS GIS] #2814: digitizer crashes, leaves vector broken
trac at osgeo.org
Fri Jan 8 03:00:38 PST 2016
Reporter: harrikoo | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.3
Component: wxGUI | Version: 7.0.2
Resolution: | Keywords: digitizer, vector
CPU: Unspecified | Platform: Unspecified
Comment (by martinl):
Replying to [comment:18 harrikoo]:
> Now it just happened again! I was drawing a test vector and crossing
lines and boundaries, breaking them and merging them, and then in the end,
deleting extra lines; immediately after the deletion of one line (select
with left, confirm with right) the digitizer crashed. This was not the
first line I deleted, perhaps the 20th, so it was something particular
about that line.
Please try to write down step-by-step instructions (or video showing all
operations) which could help us to reproduce the issue as much easy as
possible. Thanks.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2814#comment:20>
