[GRASS-dev] [GRASS GIS] #2862: v.dissolve not working
GRASS GIS trac at osgeo.org
Mon Jan 11 01:12:48 PST 2016
  Reporter:  AAHG    |      Owner:  grass-dev@…
      Type:  defect  |     Status:  new
  Priority:  normal  |  Milestone:  7.0.3
 Component:  Vector  |    Version:  svn-releasebranch70
Resolution:          |   Keywords:  v.dissolve
       CPU:  x86-64  |   Platform:  MSWindows 7
Comment (by mlennert):
 Replying to [ticket:2862 AAHG]:
 > I have pasted an example of the command and the error message below. It
 happens when used through qgis and also from the command line.
 You mean from the GRASS command line, i.e. without going through QGIS ?
 Could you please provide a reproducible example, ideally using the North
 Carolina demo data set ? 'tmp1452500056273' is not really something we can
 work with.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2862#comment:1>
