[GRASS-dev] [GRASS GIS] #2864: Add link to source code in the documentation pages.
trac at osgeo.org
Tue Jan 12 02:26:37 PST 2016
Reporter: pmav99 | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.4
Component: Docs | Version: svn-releasebranch70
Resolution: | Keywords: open science, access
CPU: Unspecified | Platform: Unspecified
Comment (by lucadelu):
Replying to [comment:4 martinl]:
> Replying to [comment:2 lucadelu]:
> > Implemented in trunk r67561. Let me know if you like it and if I can
backport it.
> I would suggest to move 'Source code' item at the end of the line (after
'Full index').
> Moreover this line contains index links (so something generic which
doesn't depend on the given module). From this POV 'source code' (linked
to the module) is strange creature here. On the other hand I don't have
better idea where to put it.
I also don't like the place, I would like to see it in the SEE ALSO
paragraph or something similar but it is to much work. Maybe the two lines
is better
> BTW, the commit contains several non-necessary changes (line
indentation), we should try to avoid them.
yes we should avoid to leave empty lines with spaces and start to follow
PEPs ;-)
Should I first commit only the cleanup and after also the changes in the
code?
My editor, correctly, is removing spaces in blank lines automatically.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2864#comment:6>
