[GRASS-dev] [GRASS GIS] #2864: Add link to source code in the documentation pages.
trac at osgeo.org
Tue Jan 12 05:01:45 PST 2016
Reporter: pmav99 | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.4
Component: Docs | Version: svn-releasebranch70
Resolution: | Keywords: open science, access
CPU: Unspecified | Platform: Unspecified
Comment (by lucadelu):
Replying to [comment:8 pmav99]:
> Thank you all,
> As far as I am concerned, the two lines seems cleaner to me. Now with
regard to the link itself.
> 1. I am not sure if hard-coding the link to trunk is the best option.
Since the documentation of multiple GRASS versions are online (i.e. 6.4,
7.0, 7.1) I think that the link should point to the respective branch.
It is hard-coded only because the idea is to have a url for each version.
there is a variable and it is changed only once. Using the dictionary
mapping it is more or less the same, when a new version will come it
should be added to the dictionary.
With only a variable there is less code and it should be a little bit
faster.
> 2. Since I guess that many users like myself don't have any particular
knowledge of the GRASS code structure, in order to make this even more
useful I think that the links themselves should directly point to the
directory that contains the command in question.
If I understand correctly it is already like that
Ticket URL: <https://trac.osgeo.org/grass/ticket/2864#comment:9>
