[GRASS-dev] [GRASS GIS] #2755: Commandline switch "/S" is not working anymore
trac at osgeo.org
Tue Jan 12 06:00:50 PST 2016
Reporter: derseppel | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: Installation | Version: 7.0.1
Resolution: | Keywords: wingrass
CPU: Unspecified | Platform: MSWindows 7
Comment (by hellik):
Replying to [comment:10 derseppel]:
> what about installing MS VC++ in "normal" (GUI) mode and just skip it in
silent mode.
> I think people (Admins) using the /S switch should be smart enough to
find out what is missing (as I already said, it should be documented
somewhere).
> ''I tend to wontfix for this ticket.'' <-- Worst you can do. I don't
think taht I am the only one who needs a silent install to deploy software
in a huge environment.
for some input:
[http://nsis.sourceforge.net/Which_command_line_parameters_can_be_used_to_configure_installers%3F
NSIS doc1]
[http://nsis.sourceforge.net/Examples/silent.nsi NSIS doc2]
[http://nsis.sourceforge.net/Docs/Chapter4.html#4.9.4.12 NSIS doc3]
4.9.4.12 IfSilent
jump_if_silent [jump_if_not]
Checks the silent flag, and jumps to jump_if_silent if the installer is
silent, otherwise jumps to jump_if_not. The silent flag can be set by
SilentInstall, SilentUninstall, SetSilent and by the user passing /S on
the command line.
IfSilent +2
ExecWait '"$INSTDIR\nonsilentprogram.exe"'
> If not, maybe your error message isn't clear enough. As you see, the
problem can be solved on many stages.
direct hints where improvement should go/code snippets/sentences for
better are messages/etc are always welcome. :-)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2755#comment:11>
