[GRASS-dev] [GRASS GIS] #2864: Add link to source code in the documentation pages.
trac at osgeo.org
Tue Jan 12 09:27:51 PST 2016
Reporter: pmav99 | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.4
Component: Docs | Version: svn-releasebranch70
Resolution: | Keywords: open science, access
CPU: Unspecified | Platform: Unspecified
Comment (by pmav99):
I am afraid that this still does not work with scripts like those in
`raster/r.li/r.li.*` and `imagery/i.ortho.photo/i.ortho.*`. Anyway,
instead of adding special cases all over the place, wouldn't a single
function be a cleaner solution?
This should also work with addons (at least I don't see why it wouldn't).
Efficiency is not really relevant in documentation generation code and
even if it is it should be addressed as a separate issue (get it working
first, fast later).
import os
import urlparse
def get_source_code_url(pgm, base_url, root_path):
Return a url to the source code of `pgm`.
If the link cannot be constructed, return the url to the repo's root
directory.
Parameters
pgm: str
The name of the GRASS command.
base_url: str
The base url of the online source code browser.
root_path: str
The relative path to repository's root directory.
url = base_url
for root, dirs, files in os.walk(root_path):
for name in dirs:
if name == pgm:
pgm_path = os.path.join(root, name)
url = urlparse.urljoin(base_url, pgm_path)
return url
return url
Ticket URL: <https://trac.osgeo.org/grass/ticket/2864#comment:13>
