[GRASS-dev] t.vect.observe.strds differences between trunk and release branch
Sören Gebbert soerengebbert at googlemail.com
Mon Jan 18 10:35:50 PST 2016
the reason behind the removal of the temporal where option was, that
it will not work in certain conditions when several STRDS are
involved. A warning will not be printed if the result is wrong. Hence,
i removed the option, since i do not have the time to implement an
always proper working solution.
Best regards
Soeren
2016-01-15 0:24 GMT+01:00 Markus Neteler <neteler at osgeo.org>:
> Hi Vero,
> On Fri, Jan 8, 2016 at 6:56 PM, Veronica Andreo <veroandreo at gmail.com> wrote:
>> Hi devs,
>> I was using t.vect.observe.strds and while reading the manual from grass71
>> (https://grass.osgeo.org/grass71/manuals/t.vect.observe.strds.html), I found
>> that in the Description section a parameter "t_where" was mentioned
>> while not listed under Parameters.
> Thanks for catching that: I have remove the reference to t_where
> parameter t.vect.observe.strds manual as it was deleted in r64560.
>> However, this t_where parameter is present for
>> t.vect.observe.strds in grass70 manual
>> (https://grass.osgeo.org/grass70/manuals/t.vect.observe.strds.html).
>> I found in trac that changeset 64560, removes t_where from trunk since it is
>> not supported in case of multiple strds sampling, but I did not find
>> something similar for release branch. Is there a reason why it should work
>> in 70 but not in 71?
> I guess it doesn't always work in relbranch70.
> Maybe Soeren knows?
> Markus
