[GRASS-dev] [GRASS GIS] #2424: PyGRASS does not work when GRASS is invoked from outside
GRASS GIS trac at osgeo.org
Mon Jan 18 19:54:43 PST 2016
  Reporter:  wenzeslaus  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  new
  Priority:  normal      |  Milestone:  7.1.0
 Component:  Python      |    Version:  svn-trunk
  ctypes                 |   Keywords:  installation, pygrass, temporal,
Resolution:              |  scripts
       CPU:              |   Platform:  MSWindows 8
  Unspecified            |
Changes (by wenzeslaus):
 * milestone:  7.0.0 => 7.1.0
Comment:
 More general but related:
 We may want to follow QGIS 3.0 ticket ''PyQGIS bootstrap is complicated''
 which suggests adding QGIS Python packages to standard Python packages
 path to avoid setting `PYTHONPATH` and perhaps other things:
 https://github.com/qgis/qgis3.0_api/issues/9
 Also note that now besides the
 [https://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly
 wiki page], we have also a pretty good
 [https://grass.osgeo.org/grass70/manuals/libpython/script.html#module-
 script.setup documentation] of the start process.
 Additionally, besides the way suggested by [comment:1 Markus]:
 export LD_LIBRARY_PATH=$(grass70 --config path)/lib
 python python_script_with_pygrass_or_ctypes.py
 we have now in trunk (after #2579):
 grass ~/grassdata/nc_spm/test/ --exec
 which ensures that the scripts runs in exactly same environment as if it
 would be executed in GRASS GIS session.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2424#comment:6>
