[GRASS-dev] [GRASS GIS] #2865: Error when installing r.modis add-on and warning when starting grass
trac at osgeo.org
Wed Jan 20 08:25:23 PST 2016
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: Addons | Version: svn-trunk
Resolution: | Keywords: r.modis
CPU: x86-64 | Platform: Linux
Comment (by martinl):
Replying to [comment:3 veroandreo]:
> I was exchanging emails with Luca regarding this issue, and he said he
tried to fix the problem reported but (quoting him, hope he doesn't mind)
"it seems bigger than expected. There is no bug in r.modis but the problem
is in lib/python/script/task.py because it doesn't find r.modis (but the
problem is there also with r.green)."
here you speak about
GRASS 7.1.svn (latlong_wgs84):~ > r.modis: Unable to fetch interface
description for command 'r.modis'.
Details: [Errno 2] No such file or directory
WARNING: Some addons failed when loading. Please consider to update your
addons by running 'g.extension.all -f'.
I guess. It's harmless error which you can ignore. Yes of course it should
be fixed. GUI is just trying to parse all addons and it's expecting that
addon name is same with command (which is not true in the case of r.modis
or r.green).
The real problem is compilation error which I was not able to reproduce.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/2865#comment:4>
