[GRASS-dev] [GRASS GIS] #2872: "r.info -e" output not compliant with eval
trac at osgeo.org
Thu Jan 21 05:37:12 PST 2016
Reporter: andbal | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Shell Scripts | Version: svn-trunk
Resolution: | Keywords: shell, r.info
CPU: x86-64 | Platform: Linux
Comment (by andbal):
I add the output of {{{r.info -e}}} executed outside {{{eval}}}
GRASS 7.1.svn (L5_Papk):~ > r.info -e map=soilheatflux.dos4
mapset=L5
location=L5_Papk
database=/home/andrea/GIS-software-data/GRASS-data
date="Thu Jan 21 09:06:28 2016"
creator="andrea"
title=" (soilheatflux.dos4)"
timestamp="none"
units="none"
vdatum="none"
source1=""
source2=""
description="generato da i.eb.soilheatflux"
comments="i.eb.soilheatflux albedo="albedo.dos4" ndvi="ndvi.dos4"
temperature=\"toa_temp.6" netradiation="rad.M1"
localutctime="overpass_utc" outpu\t="soilheatflux.dos4""
Another person suggest me that maybe is a quotes problem in the
{{{comments}}} field.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2872#comment:1>
