[GRASS-dev] hierarchical segmentation
Markus Neteler
neteler at osgeo.org
Fri Jan 22 00:34:34 PST 2016
On Wed, Jan 20, 2016 at 11:13 AM, Margherita Di Leo <diregola at gmail.com> wrote:
> Hi,
> I haven't been using lately i.segment.hierarchical (addon), at the time I
> installed it the first time (2014) I remember I had to tweak the
> installation because it wouldn't compile. Today I tried g.extension and it
> doesn't compile, but I forgot the trick meanwhile ..
I can confirm the problem (F23):
GRASS 7.1.svn (nc_spm_08_grass7):~ > g.extension i.segment.hierarchical
Fetching <i.segment.hierarchical> from GRASS GIS Addons repository (be
patient)...
Compiling...
Makefile:17: warning: overriding recipe for target
'/home/neteler/tmp/grass7-neteler-14002/tmp5NNeQD/i.segment.hierarchical/etc/i.segment.hierarchical'
/home/neteler/software/grass71/dist.x86_64-pc-linux-gnu/include/Make/ScriptRules.make:19:
warning: ignoring old recipe for target
File "/home/neteler/tmp/grass7-neteler-14002/tmp5NNeQD/i.segment.hierarchical/scripts/i.segment.hierarchical",
line 155, in <module>
raise ImportError("Not able to find the path %s directory." % path)
ImportError: Not able to find the path None directory.
make: *** [i.segment.hierarchical.tmp.html] Error 1
ERROR: Compilation failed, sorry. Please check above error messages.
Markus
> I can dig into it, ok, but can't this be fixed? and moreover, as it is such
> a convenient tool to be used in combination with i.segment, wouldn't its
> place better be merged with i.segment, perhaps adding an option for
> performing hierarchical segmentation?
> Dai Pietro..! :)
> Cheers,
> Margherita Di Leo
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
