[GRASS-dev] GRASS on OS X El Capitan - slowly dying or is something happening?
Rainer M Krug
Rainer at krugs.de
Fri Jan 22 00:39:33 PST 2016
First of all thanks a lot for the positive responses from William and
Michael that GRASS on OS X is not dying - this makes me feel much better.
Furthewr responses below in text.
Michael Barton <Michael.Barton at asu.edu> writes:
> AFAICT, the binaries I am compiling under Mavericks work with El
> Capitan IF you turn off System Integrity Protection (to get to the
> same level of security available in Mavericks).
That is good to know.
> I have not yet updated to El Capitan because I'm hoping someone can
> tell me if they can compile GRASS with it. I don't want to get to
> situation where I can't produce binaries for the community. But I
> would like to upgrade pretty soon.
I upgraded and apart from GRASS and the bash variables which are not
passed on to new processes started via Finder (sorry - no reference for
this at hand) did not regret it - but as you say, your binaries are
quite important for the community.
> There are several things in process right now. William, Brian Miles,
> and I have talked about how to deal with the SIP problem. William has
> an idea of why it is a problem. Fixing it will require significant
> change for how dependencies are packaged and referenced. This related
> to the second thing.
Good to know.
> We've had to compile GRASS with dual 32 bit/64 bit architecture for
> several years because v. 2.8.x of wxPython is 32 bit and subsequent
> versions of wxPython did not work well or did not work with GRASS.
> We've started trying again to get GRASS working with 64 bit wxPython 3
> and are having some success. (If anyone wants to test a version,
> please let me know and I'll provide a link to a binary). Because we
> have to package wxPython with GRASS, and the 32/64 bit dual
> architecture compilation is causing increasing problems, we need to
> solve that.
> If we can get these things worked out, I hope someone can try to
> compile GRASS with El Capitan and stock Mac Python, etc. to make sure
> it all works.
I must say I am a homebrew user, and I compiled GRASS from source on El
Capitan. Following the steps described in earlier emails, I was able to
compile and install GRASS, although it still needs the source directory
where it is compiled to run (I guess this is what you are referring
above).
I am happy to try to compile it and try it out (although I am not using
GRASS directly, only from R). But I have python 2.7.11 from homebrew. I
have also python 3.5.1 installed via homebrew.
Let me know if I can help with compiling / testing as I would like to
have it running again in homebrew as well.
Cheers,
Rainer
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Jan 21, 2016, at 6:51 AM, grass-dev-request at lists.osgeo.org
> wrote:
> From: Rainer M Krug <Rainer at krugs.de>
> Subject: Re: [GRASS-dev] GRASS on OS X El Capitan - slowly dying
> Date: January 21, 2016 at 2:01:56 AM MST
> To: William Kyngesburye <woklist at kyngchaos.com>
> Cc: <grass-dev at lists.osgeo.org>, William Kyngesburye
> <kyngchaos at kyngchaos.com>
> William Kyngesburye <woklist at kyngchaos.com> writes:
> There are a couple ideas floating around.
> I'm surprised Homebrew has a problem. Since it would leave
> everything
> in the configured location (/usr/local), there should not be
> library
> paths pointing somewhere else that would need
> DYLD_LIBRARY_PATH to
> divert.
> homebrew is compiling in a temporary location, and than installing
> it to
> /usr/local/Cellar/.
> The problem is the same why I had to install and than compile
> again:
> | bash-4.3$ make
> | if [
> "/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/scripts/d.out.file"
> != "" ] ; then
> GISRC=/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/demolocation/.grassrc70
> GISBASE=/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0
> PATH="/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/bin:/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/bin:/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/scripts:$PATH"
> PYTHONPATH="/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/etc/python:/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/gui/wxpython:$PYTHONPATH"
> DYLD_LIBRARY_PATH="/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/bin:/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/scripts:/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/lib:/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/lib:"
> LC_ALL=C
> --html-description < /dev/null | grep -v '</body>\|</html>' >
> d.out.file.tmp.html ; fi
> | dyld: Library not loaded:
> /usr/local/Cellar/grass-70/7.0.1/grass-7.0.1/lib/libgrass_gis.7.0.1.dylib
> | Referenced from:
> /private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/bin/g.parser
> | Reason: image not found
> | make: *** [d.out.file.tmp.html] Error 1
> | rm d.out.file.tmp.html
> | bash-4.3$
> During make, the html documentation is created. For this,
> libgrass_gis.7.0.1.dylib is needed. It is already compiled, but
> not
> installed.
> It is in
> | bash-4.3$ ls -la
> /private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/lib/libgrass_gis*
> | -rwxr-xr-x 1 rainerkrug wheel 218244 Jan 21 09:37
> /private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/lib/libgrass_gis.7.0.1.dylib
> | lrwxr-xr-x 1 rainerkrug wheel 24 Jan 21 09:37
> /private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/lib/libgrass_gis.dylib
> -> libgrass_gis.7.0.1.dylib
> | bash-4.3$
> And I assume the path where it is located is in the DYNLIB_
> variable
> which is ignored.
> This problem should be solvable, when somehow the path to the
> compiled
> (but not installed) could be temporarily added during the make.
> Any suggestions how this could be done?
> Rainer
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160122/b7f78cfa/attachment.sig>
