[GRASS-dev] Problem with the wxpython gui
Ahmadou Dicko
dicko.ahmadou at gmail.com
Fri Jan 22 04:41:19 PST 2016
Hello,
I have an error with wxpython GUI using the latest version and commit of
GRASS 7.1
g.version -rge
version=7.1.svn
date=2016
revision=67468M
build_date=2016-01-02
build_platform=x86_64-pc-linux-gnu
build_off_t_size=8
libgis_revision=67275
libgis_date="2015-12-20 12:50:48 +0000 (Sun, 20 Dec 2015) "
proj4=4.9.1
gdal=2.0.1
geos=3.5.0
sqlite=3.9.2
The error is from ./gui/wxpython/core/gconsole.py line 384
if Debug.GetLevel() == 0 and grass.debug_level(force=True) == 0:
In the version of python grass script I use, the command
grass.debug_level(force=True) raises an error.
For now, I can use the gui by replacing grass.debug_level(force=True) by
grass.debug_level().
I want to know if I'm anyone has experienced this bug and if the fix will
not cause other issues ?
Best,
Ahmadou H. DICKO
statistician economist (Ingénieur Statisticien Économiste)
PhD candidate in Climate change economics
Faculty of economics and managment - Cheikh Anta Diop University
West African Science Service Center on Climate Change and Adaptated Land
Use (WASCAL)
Center for Development Research (ZEF) - University of Bonn
email : ahmadou.dicko at ucad.edu.sn
twitter : @dickoah
github : github/dickoa <https://github.com/dickoa>
tel : +221 33 827 55 16
portable: +221 77 123 81 69
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160122/e823a242/attachment.html>
