[GRASS-dev] cp -r vs -R in make
Anna Petrášová
kratochanna at gmail.com
Mon Jan 25 11:55:22 PST 2016
I just ran into a problem when compiling an addon on Mac OS X:
Compiling...
Installing...
cp: the -H, -L, and -P options may not be specified with the -r option.
make: *** [install] Error 1
It seems cp -r (lowercase r) is not portable, see [1]. Mac cp man page says:
Historic versions of the cp utility had a -r option. This implementation
supports that option; how-ever, however, ever, its use is strongly
discouraged, as it does not correctly copy special files, symbolic links,
or fifo's.
lowercase r is used on couple of places, mainly include/Make/Install.make.
So my question is if anyone thinks there are some valid reasons for using
lowercase r.
Thanks,
Anna
[1]
http://unix.stackexchange.com/questions/18712/difference-between-cp-r-and-cp-r-copy-command
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160125/8fc3a9e5/attachment.html>
