[GRASS-dev] i.segment.hierarchical make pb
Yann
yann.chemin at gmail.com
Mon Jan 25 12:43:11 PST 2016
Please confirm this is expected, it is new from today on my Ubuntu machine.
thx,
Yann
yann at yann-ok:~/dev/grass-addons/grass7/imagery/i.segment.hierarchical$
make MODULE_TOPDIR=~/dev/grass_yann/
Makefile:17: warning: overriding recipe for target
'/home/yann/dev/grass_yann/dist.x86_64-pc-linux-gnu/etc/i.segment.hierarchical'
/home/yann/dev/grass_yann//include/Make/ScriptRules.make:19: warning:
ignoring old recipe for target
if [
"/home/yann/dev/grass_yann/dist.x86_64-pc-linux-gnu/scripts/i.segment.hierarchical"
!= "" ] ; then
GISRC=/home/yann/dev/grass_yann/dist.x86_64-pc-linux-gnu/demolocation/.grassrc71
GISBASE=/home/yann/dev/grass_yann/dist.x86_64-pc-linux-gnu
PATH="/home/yann/dev/grass_yann/dist.x86_64-pc-linux-gnu/bin:/home/yann/dev/grass_yann/dist.x86_64-pc-linux-gnu/bin:/home/yann/dev/grass_yann/dist.x86_64-pc-linux-gnu/scripts:$PATH"
PYTHONPATH="/home/yann/dev/grass_yann/dist.x86_64-pc-linux-gnu/etc/python:/home/yann/dev/grass_yann/dist.x86_64-pc-linux-gnu/gui/wxpython:$PYTHONPATH"
LD_LIBRARY_PATH="/home/yann/dev/grass_yann/dist.x86_64-pc-linux-gnu/bin:/home/yann/dev/grass_yann/dist.x86_64-pc-linux-gnu/bin:/home/yann/dev/grass_yann/dist.x86_64-pc-linux-gnu/scripts:/home/yann/dev/grass_yann/dist.x86_64-pc-linux-gnu/lib:/home/yann/dev/grass_yann/dist.x86_64-pc-linux-gnu/lib:"
LC_ALL=C
--html-description < /dev/null | grep -v '</body>\|</html>' >
i.segment.hierarchical.tmp.html ; fi
File
"/home/yann/dev/grass_yann/dist.x86_64-pc-linux-gnu/scripts/i.segment.hierarchical",
line 153, in <module>
set_path("i.segment.hierarchical")
File
"/home/yann/dev/grass_yann/dist.x86_64-pc-linux-gnu/etc/python/grass/pygrass/utils.py",
line 306, in set_path
return grasscore.set_path(modulename=modulename, dirname=dirname,
AttributeError: 'module' object has no attribute 'set_path'
/home/yann/dev/grass_yann//include/Make/Html.make:14: recipe for target
'i.segment.hierarchical.tmp.html' failed
make: *** [i.segment.hierarchical.tmp.html] Error 1
rm i.segment.hierarchical.tmp.html
Yann Chemin
Address: 3 Toul Melin, 56400 Plumergat
Mobile: +33 (0)7 83 85 52 34
