[GRASS-dev] r67535: pygrass: change dirname in set_path()
Markus Neteler neteler at osgeo.org
Tue Jan 26 03:54:21 PST 2016
On Mon, Jan 25, 2016 at 9:05 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> In r67669 I moved the functions to grass.script.utils to avoid ctypes
> dependency. Backwards compatibility is kept. Documentation says depreciated.
> Old functions can be removed in 8.0.
> https://trac.osgeo.org/grass/changeset/67669
For the record, added to
https://trac.osgeo.org/grass/wiki/Grass8Planning
Markus
