[GRASS-dev] Layer Manager notebook
Anna Petrášová
kratochanna at gmail.com
Tue Jan 26 19:20:52 PST 2016
On Tue, Jan 26, 2016 at 2:56 AM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> On 26/01/16 03:02, Anna Petrášová wrote:
>> Hi,
>> I plan to change the style of the Layer Manager tabs in the bottom of
>> the window from wx.FlatNotebook to wx.Notebook. The results look like
>> this:
>> https://drive.google.com/file/d/0B1j-R6U3_Ct9RFd1V3JSbDRjdGc/view?usp=sharing
>> Reasons include:
>> * FlatNotebook behaves strangely on Ubuntu 15+ with wxpython3 wxGTK,
>> switching tabs doesn't work well
>> * FlatNotebook rendering glitch on MacOSX with wxpython 3 (visible in
>> the screenshot)
>> * FlatNotebook causes crashing when switching from 3D to 2D on MacOSX
>> with wxpython 3 http://trac.wxwidgets.org/ticket/16357
>> * FlatNotebook probably causes loosing focus when switching to command
>> console
>> * FlatNotebook probably causes some GDK critical warnings on Ubuntu
>> Overall, by using native widget (wx.Notebook) we avoid many glitches.
> +1
> However, the appearance will be different for different OS. I personally
>> don't have problem with that, but I would suggest applying this to Mac
>> and Linux, not Windows, because on Windows it looks ugly and since we
>> still use wxpython 2.8, the described glitches don't apply there.
>> Opinions?
> I think that ideally, whenever possible, we should avoid having different
> treatments for different OS's. But if you all think that the windows
> version looks too ugly (I'm quite insensitive to such issues, so not a good
> judge), then +1 as long as windows is still wxpython 2.8.
Done in r67679.
>> Related to this, any opinion on making the labels of the tabs shorter?
> For me they can be as short as you want, as I know what they are about,
> but we have to try to think like a GRASS newbie, here. So, my reflections
> in detail:
>> Map layers -> Layers
> +1
> Command console -> Console
>> Search modules -> Search
> For these two I'm not sure if the short version is clear enough on what
> these are about: will most users understand what a 'Console' is ? At what
> is it you can search there ?
I would think console is pretty clear, but that's just my feeling. I agree
Search is ambiguous, although it might not be a huge problem for users.
> Data catalogue -> Catalogue
this was supposed to be catalog
> +1
> Python shell -> Python
> Again, not sure if just 'Python' is enough to make it clear.
> IIUC, the reason for shortening is essentially OSX, or ? Wouldn't it be
> possible to just slightly reduce font size ?
Not just Mac, in my case last tab is hidden but I can see a small arrow
showing that there is another tab. We don't have to decide this now, I was
thinking about this for some time and I was wondering if others agree we
need this.
Thanks,
Anna
> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160126/e392c4ed/attachment-0001.html>
