[GRASS-dev] [GRASS GIS] #2878: "v.in.ogr -i" throws an error when importing a GeoJSON file containing a single point.
trac at osgeo.org
Wed Jan 27 12:12:17 PST 2016
single point.
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: Vector | Version: unspecified
Resolution: | Keywords: v.in.ogr v.import
CPU: Unspecified | Platform: Unspecified
Comment (by pmav99):
Some additional info:
1. I create a new vector containing two points and I export it:
v.out.ogr input=reservoir_point at damflood type=point output=sample.json
format=GeoJSON
Exporting 2 features...
v.out.ogr complete. 2 features (Point type) written to <sample> (GeoJSON
format).
2. These are the contents of the file. This is directly created by
GRASS/GDAL:
GRASS 7.0.3svn (damflood):~/repo > cat sample.json
"type": "FeatureCollection",
"crs": { "type": "name", "properties": { "name":
"urn:ogc:def:crs:OGC:1.3:CRS84" } },
"features": [
{ "type": "Feature", "properties": { "cat": 1 }, "geometry": { "type":
"Point", "coordinates": [ -78.690549087210798, 35.769783222348899 ] } },
{ "type": "Feature", "properties": { "cat": 2 }, "geometry": { "type":
"Point", "coordinates": [ -78.687924462941851, 35.769783222348899 ] } }
3. I try to import the new `GeoJSON` file using `v.import`, but it is
failing:
v.import input=/home/grassuser/repo/sample.json output=asdf
ERROR: Syntax error in cell header
ERROR: Unable to create location from OGR datasource
</home/grassuser/repo/sample.json>
4. Importing directly using `v.in.ogr` works without problems:
v.in.ogr input=/home/grassuser/sample.json output=asdf
Check if OGR layer <OGRGeoJSON> contains polygons...
Column name <cat> renamed to <cat_>
Importing 2 features (OGR layer <OGRGeoJSON>)...
Building topology for vector map <asdf at damflood>...
Registering primitives...
2 primitives registered
2 vertices registered
Building areas...
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
Number of nodes: 0
Number of primitives: 2
Number of points: 2
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
5. Trying to create a new location using `v.in.ogr -i` fails. This failure
is actually the reason that `v.import` fails too (step 3):
v.in.ogr -i --verbose input=/home/grassuser/repo/reservoir_point.json
output=qwer location=new_location
Location <new_location> created
Ticket URL: <http://trac.osgeo.org/grass/ticket/2878#comment:4>
