[GRASS-dev] [GRASS GIS] #2878: "v.in.ogr -i" throws an error when importing a GeoJSON file containing a single point.
trac at osgeo.org
Thu Jan 28 05:34:52 PST 2016
single point.
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Vector | Version: svn-releasebranch70
Resolution: | Keywords: v.in.ogr v.import
CPU: Unspecified | Platform: Unspecified
Comment (by pmav99):
Replying to [comment:10 neteler]:
> One question we have to answer is whether GRASS should allow the
creation of mapsets with 0 resolution in any direction, and, if not (as I
think it should be), then what would be a reasonable default when creating
a location from a file containing data with identical coordinates in
either of the directions or with just one point.
I also tried to create a location using the grass binary and a GeoJSON
file containing a single Point:
grass -e -c /path/to/test.json ~/grassdata/newlocation
The location gets created without any errors/warnings but when you try to
open the location you get the following traceback:
grassuser at 2b7a187f3320:~$ grass -e -c ~/scenes/foo.json ~/grassdata/qwer/
WARNING: Default locale settings are missing. GRASS running with C locale.
WARNING: Searched for a web browser, but none found
Creating new GRASS GIS location/mapset...
Cleaning up temporary files...
grassuser at 2b7a187f3320:~$ grass ~/grassdata/qwer/
Launching <wxpython> GUI in the background, please wait...
GRASS 7.0.3svn (qwer):~ > Traceback (most recent call last):
File "/usr/local/src/grass-trunk7/dist.x86_64-pc-linux-
gnu/gui/wxpython/wxgui.py", line 141, in <module>
sys.exit(main())
gnu/gui/wxpython/wxgui.py", line 132, in main
app = GMApp(workspaceFile)
gnu/gui/wxpython/wxgui.py", line 49, in __init__
wx.App.__init__(self, False)
File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py",
line 7981, in __init__
self._BootstrapApp()
line 7555, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
gnu/gui/wxpython/wxgui.py", line 83, in OnInit
workspace=self.workspaceFile)
gnu/gui/wxpython/lmgr/frame.py", line 223, in __init__
self.NewDisplay(show = False)
gnu/gui/wxpython/lmgr/frame.py", line 1793, in NewDisplay
showMapDisplay = show)
gnu/gui/wxpython/lmgr/layertree.py", line 181, in __init__
Map = self.Map)
gnu/gui/wxpython/mapdisp/frame.py", line 188, in __init__
self.MapWindow2D.InitZoomHistory()
gnu/gui/wxpython/mapwin/buffered.py", line 1743, in InitZoomHistory
self.zoomhistory.append((self.Map.region['n'],
KeyError: 'n'
and this dialog:
[[Image(http://i.imgur.com/lXEVltS.png)]]
Ticket URL: <https://trac.osgeo.org/grass/ticket/2878#comment:12>
