[GRASS-dev] [GRASS GIS] #2878: "v.in.ogr -i" throws an error when importing a GeoJSON file containing a single point.
trac at osgeo.org
Thu Jan 28 09:22:31 PST 2016
single point.
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Vector | Version: svn-releasebranch70
Resolution: | Keywords: v.in.ogr v.import
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:13 mlennert]:
> Replying to [comment:12 pmav99]:
> > Replying to [comment:10 mlennert]:
> > > One question we have to answer is whether GRASS should allow the
creation of mapsets with 0 resolution in any direction, and, if not (as I
think it should be), then what would be a reasonable default when creating
a location from a file containing data with identical coordinates in
either of the directions or with just one point.
> > I also tried to create a location using the grass binary and a GeoJSON
file containing a single Point. The location gets created without any
errors/warnings but when you try to open the location you get the
following traceback:
> Yes, g.proj should have the same issue, so I think the solution will not
be in v.in.ogr, but at library level. Just no time right now to look into
it.
Didn't have the time, but took some anyway, but only for coding, not much
for testing. Try attached patch against trunk.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2878#comment:14>
