[GRASS-dev] [GRASS GIS] #2878: "v.in.ogr -i" throws an error when importing a GeoJSON file containing a single point.
trac at osgeo.org
Thu Jan 28 12:17:09 PST 2016
single point.
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Vector | Version: svn-releasebranch70
Resolution: | Keywords: v.in.ogr v.import
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:14 mlennert]:
> Replying to [comment:13 mlennert]:
> > Replying to [comment:12 pmav99]:
> > > Replying to [comment:10 mlennert]:
> > > > One question we have to answer is whether GRASS should allow the
creation of mapsets with 0 resolution in any direction, and, if not (as I
think it should be), then what would be a reasonable default when creating
a location from a file containing data with identical coordinates in
either of the directions or with just one point.
> > > I also tried to create a location using the grass binary and a
GeoJSON file containing a single Point. The location gets created without
any errors/warnings but when you try to open the location you get the
following traceback:
> > Yes, g.proj should have the same issue, so I think the solution will
not be in v.in.ogr, but at library level. Just no time right now to look
into it.
> Didn't have the time, but took some anyway, but only for coding, not
much for testing. Try attached patch against trunk.
I just slightly modified the patch to create a region just around the
point or line with epsilon*2 as distance.
However, a location created via g.proj location= fails, this time
apparently because of 3D region parameters. And the grass -c also fails,
but the DEFAULT_WIND files are not identical between the two methods. I
don't really understand why at first glance as the startup script method
seems to just call g.proj...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2878#comment:15>
