[GRASS-dev] [GRASS GIS] #2799: wxGUI: display toolbar size too large
trac at osgeo.org
Thu Jan 28 17:47:54 PST 2016
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: wxGUI | Version: svn-releasebranch70
Resolution: | Keywords: wxGUI, size, toolbar, mapdisp
CPU: Unspecified | Platform: Unspecified
Changes (by wenzeslaus):
* keywords: wxGUI => wxGUI, size, toolbar, mapdisp
Comment:
I think that splitting it into two parts would make it quite uncomfortable
when moving the toolbar(s) out of the windows (you would have to fiddle
with two instead of one). The handle at the beginning of the toolbar would
make the whole toolbar longer. Putting into two rows is not really an
option for small (all?) screens.
In r67699 I have removed the separators which I think were not necessary.
This makes it one button shorter for me (which is not enough).
I suggest to remove ''Erase display'' and ''Print display'' buttons. I
don't think they are that useful. Opinions?
Comparing to 70 branch, trunk has one more button which is ''Select vector
feature(s)''. We also added zoom to region recently. Both should be
definitively there but we should keep in mind that we've already hit the
limit.
The biggest issue probably is the combo box with the different modes. I
don't know why it is so big on the screenshot from Markus. There are no
long entries in it in 70 (''2D view'', ''3D view'', ''Digitize''). For me
it is much smaller (even in trunk where there is ''Vector digitizer'' and
''Vector digitizer'') but when the window is too small and the whole combo
box wouldn't fit there, the combo box just disappears and there is an
empty space instead. These both issues might be related to wxPython or the
specific platform. However, the issue probably is that this combo box
doesn't work well in a toolbar. Further research is needed to determine if
there is some good replacement. For example, the normal toolbar buttons
are grouped under one automatically for me when the window is really small
(the string we use as internal label is shown as menu item).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2799#comment:7>
