[GRASS-dev] r.proj input field does not allow to type value
Paulo van Breugel p.vanbreugel at gmail.com
Mon Jul 4 01:49:46 PDT 2016
In the r.proj window it is not possible to type in the 'input' and
'location' fields. Instead, one can only select the layer or location using
the drop-down selection. Is this by design?I would prefer one to be able to
type the name of the location or layer name.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160704/d08eaf51/attachment.html>
