[GRASS-dev] [GRASS GIS] #3090: d.font does not change default font in monitors
trac at osgeo.org
Tue Jul 5 00:49:54 PDT 2016
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.0
Component: Display | Version: unspecified
Keywords: d.font | CPU: x86-64
Platform: Linux |
d.font -l and d.fontlist give 439 possibilities for fonts. However,
d.font font="whatever_font_from_the_439_items_list"
does not change font setting in monitors, nor raise any error/warning. The
only error appears when trying to set, for example, {{{font=romanp}}}
which is indeed listed as option in d.font manual page
(https://grass.osgeo.org/grass73/manuals/d.font.html).
Whatever font I choose, monitors keep using default roman, which IMHO
looks awful and makes that the output of d.text or d.vect.thematic, for
example, look terrible, too.
The only way I found to effectively change font for d.mon was with:
export GRASS_FONT="sans"
I use fedora 23, grass trunk r68780.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3090>
