[GRASS-dev] [GRASS-user] Grass profile problem in Ubuntu 16.04 LTS 64 bit
Maciej Sieczka
msieczka at sieczka.org
Tue Jul 5 01:23:16 PDT 2016
W dniu 05.07.2016 o 04:43, Do Thi Hang pisze:
> Please find below the error I get when I try to use profile ....
> Traceback (most recent call last):
> File "/usr/lib/grass70/gui/wxpython/mapdisp/frame.py",
> line 1043, in OnProfile
> self.Profile(rasters=rasters)
> line 1051, in Profile
> controller=self.profileController)
> File "/usr/lib/grass70/gui/wxpython/wxplot/profile.py",
> line 52, in __init__
> BasePlotFrame.__init__(self, parent=parent, size=size,
> **kwargs)
> File "/usr/lib/grass70/gui/wxpython/wxplot/base.py", line
> 88, in __init__
> self.client = plot.PlotCanvas(self)
> File "/usr/lib/python2.7/dist-
> packages/wx-3.0-gtk2/wx/lib/plot.py", line 598, in __init__
> self.HandCursor = wx.Cursor(Hand.GetImage())
> packages/wx-3.0-gtk2/wx/_gdi.py", line 1510, in __init__
> _gdi_.Cursor_swiginit(self,_gdi_.new_Cursor(*args,
> **kwargs))
> TypeError
> Required argument 'type' (pos 2) not found
Same problem on Arch Linux where wxPython 2.8 package requires wxPython
3 package. Thus one can't have wxPython 2.8 installed alone, while GRASS
wxgui defaults to wxPython 3 in case both 3 and 2.8 are installed.
Several months ago Glynn wrote
(https://lists.osgeo.org/pipermail/grass-dev/2014-October/071122.html):
> In theory, code which uses the wxPython library is supposed to use
> something like:
> import wxversion
> wxversion.select('2.8')
> import wx
Question to GRASS team: would there be any problem with adding the above
wxversion selector to all wxgui code that is not comaptible with
wxPython 3? Further in the thread Glynn suggested:
> One option would be to replace "import wx" with "import grass.wx",
> where the grass.wx module is just
> from wx import *
> The other option is to only add wxversion.select() to top-level
> modules, i.e. those which are executed as scripts rather than imported
> as modules.
Maciek
Maciej Sieczka
http://www.sieczka.org
