[GRASS-dev] [GRASS GIS] #3091: The RUN_GISBASE variable is not set correctly on FreeBSD
GRASS GIS trac at osgeo.org
Tue Jul 5 02:33:43 PDT 2016
 Reporter:  pieside     |      Owner:  grass-dev@…
     Type:  defect      |     Status:  new
 Priority:  normal      |  Milestone:  7.0.5
Component:  Default     |    Version:  7.0.4
 Keywords:  FreeBSD     |        CPU:  x86-64
 Platform:  Other Unix  |
 I'm trying to port Grass7 in the ports tree to make the installation
 easier on FreeBSD.
 The include/Make/Platform.make file contains the RUN_GISBASE variable with
 the following value:
 dist.amd64.portbld-freebsd11.0
 The compilation search the includes files (e.g., gis.h) in this directory.
 But it is empty. All the includes are located in another directory:
 dist.amd64
 Why is the first directory empty?
 This thread [https://forums.freebsd.org/threads/56766/#post-323057]
 suggests the Makefile contains rules to create those directories. I
 presume the solution lives somewhere in a file in the include/Make/
 directory but I can't figure it out
Ticket URL: <https://trac.osgeo.org/grass/ticket/3091>
